[Betamax] Ma grosse BETA
- Corsaire42
Trouvee dimanche dans un vide grenier
Une SONY BETAMOVIE BMC-100P Ele a l'air de fonctionner a peu pres il faut que je teste si elle enregistre reellment
Mais comme je n'ai qu'un scope BETAMAX SONY SL-C7F SECAM je vais avoir droit a du noir et blanc
A+ SERGE
A+ SERGE
- kiko
Re: Ma grosse BETA
Houla !!!
Ca c'est du matos !!!
Je déplace le sujet dans la section "Musée" car c'est une vrai pièce de collection
- Philac
Re: Ma grosse BETA
Moi j'ai un Bétamax Fisher ( et oui je l'avais acheté neuf )
Superbe objet, tu as touché çà à combien
- Corsaire42
Re: Ma grosse BETA
A+ SERGE
- Philac
Re: Ma grosse BETA
j'ai plein de k7 betamax dans mon grenier
- Limier de Laserdiscplaza
Re: Ma grosse BETA
On est en plein revival, là...
- Corsaire42
Re: Ma grosse BETA
Annee 1983
Overview
The BMC100 was the first video camera with video recording capability. Something we now call a camcorder. It was a revolutionary one-piece design combining a 1/2" SMF Trinicon tube camera and a compact Betamax recoder into a single hand-held unit.
The unit wieghed under 2.5kg and was able to record onto all Betamax tapes giving it a maximum recording time of 3 hours and 35 minutes with an L-830 cassette
Sony CT1021 Trinicon
Technical
Omega Wrap
Omega tape wrap system which takes up a lot less space than a conventional Betamax deck. Omega wrap reduces the size of the video head drum by employing a second set of video heads which are used to record alternate frames of picture information. This was later to be adopted in camcorders of other formats.
Superior Picture Quality
A second thing to note is that the Chroma and Luminance video information is at no point within the BMC100 combined as composite video. This means that the BMC100 was able to treat colour and luminance information seperately which resulted in superior picture quality.
Battery
The unit is powered by a compact NP-11 battery ( weighing 12Oz )located in the carrying handle.
Other features
The BMC100 has a F1.2 Lens with 6X powered zoom, a built in condenser microphone, Automatic White Balance and a pivitol optical viewfinder which incorporated 4 LED indicators.
Quick fault guide
Please click on the link if you are able to contribute a solution to this list. Submit new quick fault guide entry
Fault Solution
Dead. No power. There is a fuse located near the DC input jack. This was found to be bad and replaced. The problem happened after a switch in polarity to the DC jack.
Specifications
System
Video recording system
Rotary four-head helical scanning
Video Signal
CCIR standards, PAL colour
Audio frequency response
50Hz to 10,000Hz
Audio S/N
Better than 40dB
Inputs and outputs
Audio input
From built in Microphone or
3.5mm Jack, unbalanced
Power
DC power socket
Earphone
3.5mm Jack
Remote Pause
3.5mm Jack
Tape transport
Tape speed 18.73 mm/sec.
Maximum recording time
2 hours 10 min. (with Sony L-500 cassette)
3 hours 15 min. (with L-750) Camera
Pickup Tube
1/2" SMF Trinicon
Minimum Illumination
28 Lux
Lens
6X Power Zoom with
macro focusing.
General
Power requirements
9.6 V DC from NP-11 battery
or external DC supply
Dimensions
Approx. 125 x 220 x 357 mm (w/h/d)
including projecting parts and controls
Weight
Approx. 2.5 kg ( without battery )
http://www.PALsite.com
A+ SERGE
Overview
Technical
Omega Wrap
Battery
Other features
Quick fault guide
Fault Solution
Specifications
System
Video Signal
50Hz to 10,000Hz
Audio S/N
Better than 40dB
Inputs and outputs
Audio input
Power
DC power socket
Earphone
3.5mm Jack
Remote Pause
3.5mm Jack
Tape transport
Pickup Tube
1/2" SMF Trinicon
28 Lux
Lens
6X Power Zoom with
macro focusing.
General
Power requirements
Dimensions
Weight
A+ SERGE
Re: Ma grosse BETA
Serge : Petit joueur
j'ai 2 BMC 500P à la maison
et une BMC 100P en bien triste état...
plus serieusement, la BMC 100P en 1983 et le 1er camescope au monde, c'est a dire, la 1ere camera grand publique a embarquer le magneto dans la caméra.
et en 1985 la BMC 500P est la 1ere camera grand publique au monde a embarquer un capteur CCD de 291.000 pixels a la place du bon vieux tube trinicon.
place à l'image :
place à l'image :
- Fichiers joints
- BMC 500P
- CIMG0123.jpg (269.89 Kio) Vu 6666 fois
Re: [Betamax] Ma grosse BETA
hello ^^ une question qui me gratte en se moment...juste pour le savoir, il y a des gens qui récupère des film sur leur cassette betamax pour les mettre sur support dvd ou format dvix, pour ma par j'aimerais savoir si le system peut être inversé ^^
avoir des film ressent sur du betamax.....je trouverais sa rigolo ^^
VHS is love
Modifié en dernier par NewScreenWriter le mar. 22 avr. 2014, 22:03, modifié 1 fois.
Du style : Avatar ou Tron sur Betamax! Ce serait énorme!!!maiki a écrit :avoir des film ressent sur du betamax.....je trouverais sa rigolo ^^
grave !! j'ai déjà trouvé un site sur le net ou ils vende des cassettes betamax
sur le boncoin ils vende un lecteur betamax.....le même que dans un épisode de cowboy bebop ou ils reçoive un colis qui contient une cassette betamax qui ne rentre pas dans leur magnétoscope, alors ils parte a la recherche d'un lecteur........pour se qui connaisse pas sa se passe en 2097 lool
moi je me mettrais en chasse d'un lecteur quant j'aurai fini mon installation ^^ peu pas tout faire en même temps ^^
VHS is love
C'est facile à faire pourtant !!! Le Dvd en lecture et le Scope Bétamax en enregistrement !!Soraki a écrit :Du style : Avatar ou Tron sur Betamax! Ce serait énorme!!!maiki a écrit :avoir des film ressent sur du betamax.....je trouverais sa rigolo ^^
J'ai vendu une dizaine de carton neuf de Béta il y a quelques mois !!!
Il me reste encore un peut de matériel à vendre si ça intéresse quelqu'un, des scopes C7, une caméra raid de neuf (Servi une dizaine de fois) dans ça sacoche avec accessoire...
loool ben si tu a ou tu peu me trouvé un lecteur Sony Betamax sl-Hf 950 je te le prend c'est du garantie !! ^^ cet appareil et un véritable bijoux
le voici
le voici
VHS is love
