NewScreenWriter a écrit :Il m'a toujours semblé que le PAL + était notre version du 16/9...
Le PAL+ c'est le squeeze européen avec une résolution améliorée... C'est donc du 16/9...
Sur du LDDB :
Back in the early 90's, European Broadcaster defined and designed an extension of the PAL standard that would fit upcoming 16/9 requirements but still keep backward compatibility with existing PAL TV sets. The idea was to include an extra line (along with extra hidden format information) every 3 lines making the default 430 lines go up to 574 lines of information.
While very nice for 16/9 display, the titles mastered for PAL+ format were probably not showing the best display on regular 4/3 display. The resulting display would not dither/adapt the signal from 4 to 3 lines but rather "forget" to display 1 line every 4 lines of information. This is one step better than NTSC Squeezed LDs, but still one step below true anamorphic transfers has found on DVD today.
Movies available in PAL+ mode (Germany): Showgirls, Mikrokosmos, Schlafes Bruder
Pour le DTS, c'est tout à fait possible sur du PAL vu qu'il prend la place de la piste PCM contrairement à l'AC3 qui prend la place des pistes analogiques...
